What Causes This Damage to The Melamine Dials? "Click" to Login or Register
I've seen several Melamine dials on Hamilton 950B's with damage to the outer minute chapters.
On this watch the damage is in the form of a line through the outer chapter numerals from approximately 26 through 39. Difficult to see in the photo below, but it is there.
The other watches I've seen have similar damage in approximately the same area. Is this damage cause by someone carelessly trying to screw the front bezel back on?
Hamilton 950B
Posts: 570 | Location: Michigan in the USA | Registered: April 13, 2015
Picture of Larry Lamphier
The Melamine dial is VERY sensitive to anything touching it. On a lot of these dials you will see dark marks on the outer edge. It is from the bezel hitting the dial. Sometimes it will go all the way around the dial.
I never really thought of it the way you mentioned it Keith, but yes, if when you are putting the dial back on the watch and you hit the edge at all, you can be sure that it will leave a mark on it.
Do a search for "bezel rub" and there are 29 topics that come up. Here is one in particular;
https://ihc185.infopop.cc/eve/f...263911667#8263911667
Sometimes the bezel rub on porcelain as well as melamine dials will actually "score" the edge of a dial and will leave a permanent testament behind. It's something that for the most part, we have to live with.....
Picture of Robert Lee Milliron
Melamine dials are just SORRY. That's all there is to it.
Posts: 663 | Location: North Carolina in the USA | Registered: June 01, 2005
Thanks for the replies. The more I learn about them, the more I'm glad you guys convinced me to forego the 950B with melamine dial at this stage of my collecting.
"Scoring" is a very accurate description of what I've seen so far.
Picture of Richard Romero
It looks to me like the tip of the minute hand was rubbing.
RR
Melamine is a lot like other plastics or plastic types that don't have Ultra Violet inhibitors, they break down, shrink, and basically start to self destruct. Some are pristine and others are horrible, probably a lot of that had to do with exposure to sun or extremes of heat and cold.
Claude is correct in summing up the overall issue with melamine dials.
That authentic factory-marked "23-Jewels" melamine dial is uncommon and worthy of cleaning and preserving.
The dial in question could certainly be improved. I would carefully wipe off all debris with a soft cloth, then begin with a never-used number 2 pencil eraser around the edge (as Buster advocated above) followed by rubbing down the dial with a pink block eraser. My final erasing would be in a circular pattern going round and round the dial. Then another dusting off with a soft cloth before re-installation. I developed this method years ago and have saved many dials that might have otherwise been lost.
And I agree with Larry, we do not touch these delicate dials except on the edges in the same manner as a CD or DVD and for essentially the same reasons.
There are hundreds of "melamine" and "melamine dial" posts for those interested in research.
Hope this is of help,
Keith,
The minute hand clearly rubbed all the way around the dial on the top and cut a groove into it. By tracing that groove and putting it on the picture provided in this post it lines up with the missing ink on the 26 and 39 minute numerals. That groove diameter is too small to be from the bezel.
Working on watches I've seen many dials that do not want to sit flat on the movement. In addition some movements don't want to sit level in the case. Sometimes crystals don't sit exactly level in bezels and the hand gets pushed into the dial. Sometimes hands are not evenly pushed onto cannon pinions.
The reasons stated in the above paragraph all can contribute to a hand rubbing on one side of a dial and not cutting into evenly like the dial on the top.
Perhaps that answers your question of, " ...a line through the outer chapter numerals..."?
RR
Good work Richard,
Hard to see but it is there my friend.
I'm sure that in 1946 when they made the melamine decision at Hamilton not one person in that room would have dreamed that 69 years later there would be a group of obsessive-compulsive collectors like us examining all the fine points (and even fine scratches) on the dials they were planning to introduce.
The fact we do, and with careful preservation, might always have pristine examples means a lot.
Thank you all for the input into this thread.
Richard, I see what you mean, and your illustration of the minute hand tracking/creating the damage "groove" is very instructive. Thanks for taking the time to provide it.
I should have been more clear about the edge on the dial. It is clear that the minute hand made the marks you are talking about Richard. It is also clear that the bezel made the dark mark around the edge of the dial.
Like Lindell said, that dial can be made to look 100% better that it does now though.
I use a different method which has made many of them look almost new again, BUT you have to really understand these different Melamine dials to do it, and I would never put it on here as you can completely ruin one in less than a minute if you don't understand which melamine dial you are working on. There are many different finishes on them and even the dial itself is different and has to be treated different when working on them.
