November 03, 2011, 19:35
Roger StephensJust received Ball Waltham
16s.21jewels,s/nB206622 .Ihave the movt. no case.Dial is a little bit washed out and I have one that is very good.Thought I would replace it.There are no feet screws visable.How does the dial come off? Regards Roger
November 03, 2011, 19:57
Buster BeckIf you don't see the 3 dial screw holes, then perhaps a "dust ring" is in place and needs to be taken off
If you see the 3 dial foot screw holes, but no screws are in the holes, then start lifting it off with a blade at the set lever cut and ease around the diameter of the dial until the 3 feet are out of the holes.
Of course it could be glued or tabbed to the pillar plate. It's hardest to diagnose without pictures to see the problem or help with it.
It does sound like you possibly have a Ball Waltham, however, and not a Ball Hamilton as you stated. Perhaps you had better show us some pictures of it....
November 03, 2011, 20:23
Edward L. Parsons, Jr.Of course you will also want to remove the hands before trying to get the dial off!
November 03, 2011, 20:52
Roger StephensThanks Buster and Ed,it does have a dust cover.First time I have encountered this.I guess the next question.How does the cover come off?My camera is on the blink right now.Should have it tommorow. Roger
November 03, 2011, 21:00
Buster BeckLet's start with what you do have first..
Here is a picture, look at the case screws and where they are. In the picture a Ball Hamilton is on the LEFT and a Ball Waltham is on the RIGHT.
I think you will find you have a Ball Waltham. And in that case, you will need a Ball Waltham dial to swap out, as they do not interchange.
As to the dust ring, they are generally only hand tight. In any advent, remove the case screws, take a blade and work around the edges until it slips off.
<Ball Hamilton on LEFT ~ Ball Waltham on RIGHT>November 03, 2011, 21:14
Roger StephensThanks Buster will try that.Case screws at 11 and 5. Roger
November 03, 2011, 21:34
Roger StephensDial off new one on! Thanks Roger
November 03, 2011, 22:59
Buster BeckVery Good !!
There's a little glitch going on in this post that needs clearing up then we can say " next post " and move on !!
In the title Roger says "Just Received Ball Hamilton". Roger stated serial number B206622
That would make it a Ball Waltham as their blocked numbers in that series were B202001-B225000 from ca. 1904-1906.
On the other hand, Ball Hamilton 16sz. grade "999" serial numbers started with
B600001 around 1910 and ended with B655200 in about 1943.
Now, Roger says his watch has case screws at 11 and 5 o'clock
I believe there are two errors in this post. First, I believe it is a Ball Waltham "if" Roger quoted the correct serial number. Second, Roger stated his watch has case screws at 11 and 5 o'clock. Looking and holding Roger's watch up exactly as in the two side by side pictures that I posted and saying that the crown wheel is at 12 o'clock, then Roger's watch should have case screws at 1 and 7 o'clock just like the pictured movement on the RIGHT
I don't want someone confused in ID on a watch so perhaps we can clear this up. Also Roger successfully swapped out the dial, but it was with another Ball Waltham dial I do believe.
What do you say Roger ??
November 04, 2011, 05:16
Roger StephensBuster you are right.Looking at the rear of watch the screws are at 1 and 7.From front they are 11 and 5.Sorry for the confusion.Thanks Roger
November 04, 2011, 06:56
Buster BeckWhew !!
Perhaps the most confusing was me trying to explain all of this and express it on paper
I was beginning to doubt myself
If nothing else is garnered, we can see how important pictures are to a post. And when trying to ID a mvmt, and looking/describing a mvmt, forget about the dial side as to a relation of hours because.....
That's the other side folks
The title to this post has now been changed to " Just received Ball W-a-l-t-h-a-m" Thanks !!
