February 05, 2004, 14:00
Stephanie O'NeilCan Heat Activate Movement?
Recently I read in an ebay listing "
the watch starts to run and keeps going if the case is slightly warm, when I got it I thought it was not running, but left on a sunlit windowsill it started to run."
The watch is an English fusee movement, circa 1852.
Can heat activate movement?
Stephanie O'Neil
NAWCC Member 143979
February 05, 2004, 16:55
Aaron BereiterMaybe if the oil is old and a little bit on the thick side. It may heat up a little and begin to run although I would imagine pretty slowly.
Aaron
February 06, 2004, 02:49
Jack GoldsteinIts also a good way to get hairlines. Some people will always take things to the limit! I can see it now, holding the watch on a stick, like a hotdog, and holding it over the stove, "but it was only low heat"!!! Whats next, the microwave
Jack Goldstein
NAWCC 0152932
IHC 185 #274
http://www.ball-rr-pocketwatches.comFebruary 07, 2004, 11:52
Stephanie O'NeilAaron, thanks for your opinion.
Lindell,
Talk about learn something new and different everyday!
Thanks
Jack G.
Stephanie O'Neil
NAWCC Member 143979
