A pretty nice 992B? "Click" to Login or Register
IHC Member 1016
Looking for critical analysis. My take is this is an all original watch. I took the movement out to clean the case, and couldn't see any evidence this had even been removed from the case in past.
IHC Member 1016
The dial has some smudges that I chose to leave alone for now.
IHC Member 1016
Another
IHC Member 1016
Still another
IHC Member 1016
The movement
IHC Member 1016
The back
IHC Member 1016
I see the crown is askew a bit. Maybe I reassembled it incorrectly. It appears to me that this watch has not been used much, and possibly never even cleaned/oiled.
Mike,
That is a VERY Cool nice 992B you have there my friend.
By the way, the best way I have come up with to clean the gray marks from a melamine dial is a block eraser. Use it carefully so as to not allow it to "polish" the dial. You want a matte finish on these later dials.
Turn your crown anti-clockwise and observe whether or not there is a "wobble" to it. If it does, that is difficult to repair. If not then a slight re-positioning of the movement should set things right.
When you have a moment, please post both the movement and case numbers as we are collecting data on them. The case will most likely have a P-prefix as part of the number.
You have the strongest, most reliable and easiest to service RR Watch ever made.
IHC Member 1016
Hi Lin, The case number is indeed a P prefix #P277786, and the Movement is C491059, which lines up well with the case number. I loosened the case screws and reset the movement and the crown is now correct. I would be surprised if there is a better example that was actually used. This appears to have seen use, but very little. I'll try the eraser soon.
Mike
