A Walk through the U.S. Navy Submarine Becuna
https://ihc185.infopop.cc/eve/forums/a/tpc/f/990103944/m/2731004691
July 12, 2006, 23:56
Greg Crockett
Finding myself with some extra time in Philadelphia, PA, I walked down to the river to check out the ships I had seen during a ride on one of the local DUKW amphibious tours.
July 12, 2006, 23:58
Greg Crockett
The Becuna is not exactly an intact artifact of WWII. She was refitted several times during her long service life and no telling the vintage of the Chelsea time pieces on board.
July 13, 2006, 00:02
Greg Crockett
I was only able to locate two clocks on board. One located in the bridge/control room - screwed into the port-side, mid-ship.
July 13, 2006, 00:08
Greg Crockett
Close-up
July 13, 2006, 00:14
Greg Crockett
The second Chelsea was located in the aft torpedo room, in the back, screwed to the starboard hull. Here is a close-up with what looks like the correct sweep second hand. I don't know about the red second hand in the control room - while it does not look right for WWII, we must keep in mind that this boat was in use until 1969. Note also, the dials are white and marked U.S. Govt instead of the black U.S. Navy marked dials common during WWII. These time pieces are either of late production or they have new dials added during post WWII repairs/rebuilding to conform with new specs.
July 13, 2006, 00:20
Greg Crockett
One can see a sailors bunk over one of the “fish”. The men slept with the torpedos.
July 13, 2006, 00:34
Greg Crockett
There were no other time pieces visible, not even in the radio room, which would have had a clock with red segments to mark the radio silent intervals in WWII.
Here we have the last image, looking forward through the main passageway.
Crawling around in this cramped vessel I found great respect for the special valor of the submariner.
Best regards,
Greg
July 17, 2006, 17:05
Peter Blunsdon
Greg, you may know this, but these Chelsea clocks are/were in the control post of your 1960/1970's underground nuclear silos.(minuteman?)
I was watching a program on British TV tonight about the cold war and the presenter did a piece from an underground silo, there it was on the panel!
Peter
