My new Seth Thomas regulator No.6 "Click" to Login or Register
Picture of Jim Walz
posted January 10, 2006 16:12
I just bought this Seth Thomas No. 6 Regulator. It has a nickel engraved pendulem and weight as well as dial surround. My question is value. Has anyone seen one of these sell at auction or show? Thank you in advance.
Posts: 427 | Location: Lincoln, Nebraska in the USA | Registered: April 07, 2003
Picture of Jim Walz
posted January 10, 2006 16:14
pic 2
Picture of Jim Walz
posted January 10, 2006 16:15
pic 3
Picture of Tom Seymour
posted January 10, 2006 16:58
VERY NICE!!!!!
Great clock Jim! Tran's 2004 price guide put it at $4,500.00.
beautiful clock!!
posted January 11, 2006 11:41
Here's the same case model with a calendar in it. It has a short pendulum hanging in front of the movement with an oval hole in the pendulum to allow it to swing with the hand shaft inside the hole. The weight hangs on the right side and is compounded; the cord goes from the winding arbor up to the top of the case, around a pulley in the top, down to another pulley which hooks into the weight and then back up to dead head at the top of the case. The weight is a thin rectangular block of cast iron and is quite heavy.
posted January 11, 2006 12:10
That's a beauty. I had not seen the calendar version except in the books. It is very sharp! thanks for posting that one.
Picture of Grant Perry
posted January 18, 2006 13:25
Jim,
That is one finnnneeee clock.
Grant Perry
Posts: 334 | Location: Ottawa, Canada | Registered: January 28, 2003
posted January 18, 2006 17:43
Both clocks are just absolutely fantastic.
The finish on Jim's is probably more in keeping with today's tastes, but I love them both.
Ship either or both to Ohio whenever you tire of them... Big Grin
Picture of Jim Walz
posted January 18, 2006 22:52
Thanks I just picked it up and have a few fine clocks but probably will sell or trade it. There is a collector here in my town with a minute repeater pw 18k hc we will see.
posted January 26, 2006 20:35
John Arrowood,
I have a double dial like your Seth Thomas above. Mine does not have the correct pendulum, or rod. Can you please send me some dimensions, and images of what I should have? Thank you.
Steve
Posts: 131 | Location: Houston, Texas USA | Registered: February 12, 2003
posted January 28, 2006 14:07
Yeah, my clock isn't bright and shiny. I prefer the way it looks now; we all know how the Antiques Road Show twins frequently expound on the desirability of maintaining the original finish. This one is on an inside wall where it isn't exposed to bright natural light which fades and bleaches walnut or cherry.
Now for Steve's request:
This is going to take some time.
Here's a picture of the pendulum assembly on the clock. It would take a very talented craftsman to duplicate the complete pendulum in my opinion.
Overall length from the stud in the front plate to the end of the threaded rod for regulation is 15 1/2 inches.
posted January 28, 2006 14:13
The pendulum off the clock
posted January 28, 2006 14:25
Here's the oval keystone part. It's made from 1/32 inch brass. It's 3 inches in total length including 7/8 inch which was inserted in a slot in the wood piece and riveted. It is 1 5/8 inches wide at the widest part. The top portion is 1/2 inch wide. The rim of the oval part is 1/4 inch wide and the hole is 1 3/16 inches wide and 5/8 inch high. The slot for the end of the verge wire is 3/8 inch. The suspension spring has been replaced with a short piece of a kitchen/shelf clock suspension rod.
posted January 28, 2006 14:37
Moving on down the pendulum:
the upper piece of wood is 5 5/8 inches long and 1/2 inch wide and 9/32 inch thick. There are slots in each end for the brass material to be inserted and riveted. The bob is 3 3/4 inches wide nickel plated metal over lead. The lower portion of wood is 4 1/2 inches long, with the same width and thickness of the top piece. The threaded rod for the rating nut is 1 5/8 inches long with at least 1/4 inch inserted into the wood. The rivet attaching the two pieces is 1/4 inch from the bottom end of the stick. The hook is 1 7/8 inches in total with 1/2 inch inserted into the wood part. The hook is 3/8 inch wide.
posted January 28, 2006 14:47
Here's a back view of the complete pendulum assemby.
posted January 29, 2006 19:19
John,
You are an ace. I am sure from these images and dimensions, I can get mine closer to original. The hard part might well be finding an engine turned bob. I do appreciate your help.
