July 17, 2014, 13:54
Ken SnowdenKroeber Clock?
I bought this purely because of curiosity. It stands 35 inches tall and 18 inches wide. It is a cuckoo with a music box. The notes that came with it says that it is a Kroeber marked "11" and that the movement may be from Phelps & Bartholomew. The fretwork is wonderful. I do not know what you would call the clock. Any information would be greatly appreciated.
Ken
July 17, 2014, 13:57
Ken SnowdenIn trying to research this, I find that there is a Kroeber and a Kroeger clock company. The paper with this says that it is a Kroeber. The music box is behind the double doors on the bottom level.
July 17, 2014, 13:59
Ken SnowdenI have not had this apart yet. I do believe that the dial is a replacement with the fact that the numerals eight and four have been moved rather than being drilled through.
July 17, 2014, 16:57
Dave TurnerKen, I've researched these somewhat. I believe it has an 8 day Waterbury movement.
July 19, 2014, 13:54
Ken SnowdenDave, can you site an example of a clock like this and its movement? I don't see a Waterbury that matches up with this.
July 19, 2014, 15:58
Dave TurnerI'm not certain, but I think this example is close.
Although, the count wheel position has me wondering.
http://www.antiqueclockspriceg...ls.php?clockid=32136July 19, 2014, 19:49
"Curly" SjolanderLooks similar to me, the different count wheel and hammer wheel are probably modifications for cuckoo call on this movement. My opinion until I see one that is signed. Good work Dave you might earn another stripe on your detective badge.
Curly
July 19, 2014, 22:06
Dave TurnerHa!
Thanks Curly, that stripe and $4.50 will get me a cup of coffee.
July 19, 2014, 22:19
Ken SnowdenWhile I can see the similarity I would question the fact that both clocks are cuckoo clocks so why would the count wheel setup on mine be a modification for the cuckoo call? Perhaps two different companies used a Waterbury movement and chose different ways to modify it. I will check further and provide more pictures when I get around to working on this clock.
