February 12, 2021, 12:59
David JimenezSeth Thomas Drop Octagon 2334 Electric Movement
I have a Seth Thomas Drop Octagon model 2334-001 wall clock, which uses the D battery electric movement with chimes. The movement has an intermittent failure of the winding mechanism (clock stops).
I looked online for a replacement and the only one I find is a Japanese made Bim-Bam movement, but it is 6 1/2" wide and the original movement is only about 5 3/4". The wood case is only 6" wide (ID) and I have no desire to take a router to the case.
Anyone know of a replacement movement that is about the original size? The clock is from the late 70s or early 80s.
February 13, 2021, 08:34
Dave TurnerYou didn't say if your clock strikes, but if it doesn't you might consider this one:
https://www.clockworks.com/pro...uartz-clock-movementBut before you do that, I would recommend you take a look at it and see if it can be repaired.
Look at this video:
Pendulum Quartz
