November 26, 2004, 22:36
Ged PitchfordANSONIA @PUB CLOCK?
Hello All, Your Help and advice required, The clock has been performing so well for weeks now. It must be female, It's stopped twice this week always at 5-10 to the hour(Warning?) .Now what do I look for?, Your's and my Reputations are on the line here. Imagine ,If I can't fix it one of you will have to come over and get the job done,HELP. Ged.
November 26, 2004, 23:19
Tom SeymourGed,
It does sound like the warning. It ran for weeks, and then decided to get fussy.  Those are usually minor problems that are difficult to determine without it being in hand.  Sometimes the count lever is rubbing against the slots in the countwheel.  This can cause enough friction to stop the clock. A bent tooth on the countwheel could also cause a problem.  The best place to look for that is at the one o'clock portion of the wheel.
Lifting and locking wires, if not lubed can also cause extra friction.
Very tough to tell without having it in hand.
November 26, 2004, 23:34
Kevin PestorHi Tom, i read not good to lube lifting wires.Though i think some lubrication is better than none, just not too much.
My waterbury , the strike side does not even work, just the time side, i think that is weird.Maybe i will email you about that one.
November 27, 2004, 00:12
Tom SeymourKevin, I put a very thin touch of PML Stem Grease where the wires rub against cams or other wires.  It hasn't been a problem.
November 27, 2004, 11:05
Ged PitchfordTom, It must be Female, I arrived at 12-30 today,Sat' and there it was ticking away and keeping good time since Wed' night. I rewound it and will visit again Wed' evening. Ornery things arn't they. Regards, Ged.
November 27, 2004, 12:03
Carlos FloresGed,
Female and in England and your reputation is at risk..., seems that we have to be there, clockbusters!
November 28, 2004, 19:55
Tom SeymourClock is working???   DARN!   I was just trying to figure out a way to make a friendly call to give some assistance.....for the good of Chapter!
