August 21, 2005, 20:30
Tom SeymourKitsch...not Kitchen clock
There must be something wrong with me, but I could not pass up this (you fill in the adjective) clock.  It has a Lux dial and movement, but, no shock here, I did not find this model in the books.
It seems to have  been made as a souvenir of Santa Cruz, California.  A close look is not advised, but if one ventured to do so, you would see large gaps with a drop of glue separating the mother of pearl from the wood, and a few pieces in need of alignment.
Tom SeymourThe back shows it to be a solid block of wood with a hole cut for the movement.
August 21, 2005, 20:32
Tom SeymourThe dial is clearly marked, and Santa Cruz can be seen on the bottom.
Everybody needs one of these!!!
August 21, 2005, 23:12
Kevin PestorNeat clock Tom, what is the material attached to the wood on the front of the case,  looks interesting.
