May 13, 2013, 19:24
Thomas F. CrossettTop block screws frozen on Kundo miniatures
Two clocks I just picked up to restore have top blocks on which the screws are frozen. I have tried heat, penetrating oil, and cursing, but with no luck. Any ideas short of buying a bag of top blocks?
May 16, 2013, 23:37
Bill CarlsonTOM,
You can get the suspension spring you need here!
I've seen a few of those blocks you could destroy before getting a screw to come loose. This is the easy way to fix it.
http://stores.thehorolovarcompany.com/StoreFront.bokMay 17, 2013, 07:26
George UlrichTry to find kroil this is the best penetrating oil made literally will loosen bolts that are totally rusted together, a couple of drops laying flat allow a day or so to soak in they will turn out. george
