December 12, 2002, 12:36
John ArrowoodANSONIA KITCHEN/SHELF
I posted some pictures of my Ansonia kitchen clock on my web page:
http://home.att.net/~aejohnAnyone know the name of this model? When I picked it up the top and the rest of the case parted company, been in the basement too long.
December 12, 2002, 16:36
Tom SeymourJohn, I have looked in Tran Duy Ly's book on Ansonia clocks, and in the 1901 Ansonia Catalogue and did not find it in either place. There were many close relatives....similar styles.....but not the one you pictured. I'll keep looking in other sources. Maybe someone else has spotted it in another book.
NAWCC #41293
Internet Horology Chapter #104
Interim Exec. V.P. of IHC
December 12, 2002, 23:47
Tom SeymourJohn, I have also checked Gilbert, Sessions, Ingraham and New Haven books. All have clocks that have similar features. I could not, however, find any with the same drop finials as yours. Nor caould I find any with the coin-like medallion at the top. I figured those would be key features to track down a maker.
No luck so far. I'll get back to you if I come up with something further.
The movement sure doesn't look like it fits the case.
NAWCC #41293
December 13, 2002, 07:04
John ArrowoodThanks for looking, I appreciate the help.
December 15, 2002, 23:15
Tom SeymourJohn, I have also checked in a couple of books on Canadian clocks, but no luck. It is a common style, but none of the case details on your case match what I see in the books. I can't even see a glass that seems to match up with yours.
I'll still keep an eye out.
NAWCC #41293
December 16, 2002, 06:59
John ArrowoodThanks again, I do appreciate all the help. I took the movement out of the case yesterday and it definitely belongs with that case. It appears that sometime when it was serviced, the left side mounting holes were stripped and the movement was rotated just a bit in a clockwise direction on the lower right mounting screw to expose a new suface for the left hand screws. The holes were closed up with glued-in pegs and they match the holes in the mounting brackets perfectly. There is no indication that there ever was a screw in the upper right mounting bracket.
December 16, 2002, 14:46
Tom SeymourJohn, I have noticed on some clocks that the mounting feet are held with a single rivit. These are often rotated to provide a fresh footing for the screw. The original alignment with the dial is not disturbed by doing that.
Some, however have two rivits and obviously cannot be turned. IIf the old holes were plugged with wood, it would probably be ok to put the screws back in their original position.
NAWCC #41293
