August 19, 2005, 22:48
Tom SeymourElectric Timers
Here is one example of an old electric timer. I thought this one was interesting. Lots of style in some of these old things.
Any other examples out there?
August 20, 2005, 16:42
Samie L. Smithhere is a G.E. timer not as nice as yours..it has a lever at each 15 minute mark that you pull out to set the time for on and off on the timer..also has a 3 position switch on the back marked aut. off and on..picked this up at the 127 yard sale .
August 20, 2005, 16:49
Samie L. Smithhere is a timer of sorts this one is called the High Time Ceiling clock you set the time you want it to come on and go off from the back..It shows the time on the ceiling via a small bulb and refector inside the case..it still works and is quite a novelity.
