April 06, 2007, 09:26
Mark NathansonPic-Terhume & Edwards Clock-Newbie To This Name?
Showing a picture of above clock. I haven't heard of this maker.Is this rareor a common name with clocks. Is it collectable? Info appreciated, thanks. Estimate of value also appreciated.
April 07, 2007, 20:25
Derek B. PhelpsNot a rare maker or style but if the stenciling and paint is original, a very nice clock. These little iron fronts are attractive clocks. The hands are correct but the dial appears to be a little too clean but could be original (maybe the flash brighten it up some in the photo). I have a F. Kroeber in the same style. Do you own it or thinking of acquiring? I would look closely at the paint and finish, a lot of these were repainted. This one has a lot of detail so it kinda makes me suspect a little but it could be right! I'd check to see if it had either wall paper or a label on the inside. Terhume & Edwards did the casting for a lot of iron fronts and sold them to other makers to finish out.
