March 13, 2012, 16:50
Patrick WallinPush here don't work....SOLVED
I have several watches that the push here button (Stem release) does nothing. Any ideas? I m a pocket watch guy so need a little help here.
Patrick 1616
March 14, 2012, 00:23
Robert V. JonesPatrick some quartz watches the crown needs to be pulled out in setting position and then push the push button and it should pull out. I know some do it out and some in. See if that works
March 14, 2012, 00:24
Robert V. JonesLet me rephrase that while pushing button down it should pull out.
March 14, 2012, 22:58
Eugene BuffardMost Quartz watches the stem has to be pushed in. Then depress the stem release button on the quartz watch. While pulling out the stem.
NOT in the hand set mode,
On an bulova Accutron the stem needs to be in the Hand set mode while unscrewing the Set lever screw.
March 14, 2012, 22:59
Eugene BuffardI hope it clears the mud a little.
March 18, 2012, 11:32
Patrick WallinThanks Rob & Eugene, Ill try that....
Patrick
