May 05, 2007, 09:11
Dan MitchellWhich wristwatch did you wear today?
Adam - it seems the Gladstone was often a present in 1931 - it was a rather large watch for the times. I just finished fitting a refinished dial to my wgf Gladstone when your ggf version appeared.
Dan.
May 05, 2007, 09:30
Adam M. DubinDan, the wgf Gladstone looks swell on that black pigskin strap, the only problem with those available these days is that they seem to come only in 18 mm and 20 mm, not the 19 mm which is the lug width for the Gladstone. Anyone have a source for 19 mm pigskin straps?
Today I have on my Oyster Centregraph, ca. 1940, one of the myriad of mid-sized Oyster watches made by Rolex for the WWII Canadian market, all having the fine cal. 59 movement.
May 06, 2007, 05:15
Dan MitchellThe Gladstone has female spring bars - and because of this it is easier to get the strap on/off if it is a tiny bit narrower than the lugs - so an 18 mm strap does just fine.
Anyone know where to get female spring bars new ?
Dan.
May 06, 2007, 08:10
Adam M. DubinDan, I know an 18 mm strap does fine, but a 19 mm does better! (I personally don't care for the extra mm showing on each end, but I am a bit obsessive-compulsive) Unfortunately, new female springbars of this size are no longer available, but occasionally one gets lucky asking around. I got a few thusly at one point last year.
May 06, 2007, 18:34
Cary HurtDan,
Jules Borel lists female spring bars in 8mm through 19mm sizes. I have some of these as well as some old stock ones. Let me know what you need, and I may be able to fix you up for a postage stamp.
Cary
May 13, 2007, 16:06
Philip MenaHere is a nice Hamilton B Barrel engraved WGF.
May 14, 2007, 15:33
Adam M. DubinRe: springbars for the Gladstone...I went through this last year when the spring of one of mine broke while changing straps. Apparently the new production 19 mm female springbars are of too narrow a caliber to fit properly over the stout male endpieces of the lugs (sorry if this sounds vaguely pornographic). I was lucky to find a fellow collector who could spare a few old ones, one of which was the correct size. I will treat the original female springbars of my Gladstone, Meadowbrook, Piping Rock, and Coronado with great care from now on!
May 18, 2007, 19:58
Adam M. DubinThis Omega, ca. 1935, cal. 26.5 (15J), 3/4 size (30 mm), in stainless steel.
May 18, 2007, 19:59
Adam M. DubinThere is some light patina on the dial, but that's a shadow in the above pic. Here's another view.
June 01, 2007, 10:55
Adam M. DubinCome on, you all must be wearing a watch at this very minute, no?
Here is a modest beauty I have on today, a 10K rolled gold plated Longines with 15 jewel movement (sorry no movement shot). The case is marked "W", so I think it's Wadsworth. The dial is pretty well preserved. Ca. early-mid '30s.
June 01, 2007, 10:57
Adam M. DubinSide view. It's a pretty small watch (22 x 37mm).
June 05, 2007, 11:18
Dan MitchellToday, after further work on it on Sunday, I wore my 988 wristwatch on my weekly supermarket visit.
Dan
June 07, 2007, 19:47
Stephen Ollman1927 Bulova Lone Eagle - Original 5000<br>
See other Bulova watches at
http://www.mybulova.com<br>
June 09, 2007, 06:40
Adam M. DubinAnother stainless steel Omega, ca. 1936.
June 15, 2007, 13:36
Brad Cohn
hamilton grant in sterling case.
June 15, 2007, 13:49
William J. Hansen, Ph.D. I love the sterling silver grant. They are most often seen in yellow gold fill. The sterling silver variety is considerably more rare. I don't have Rene's book in front of me, so I can't tell you his research. I know I've seen only a few in the past 6 years. For what it is worth, International Dial could redo the dial and hands in a "warm luminous" stlye that might dress up the watch nicely.
Bill Hansen
IHC# 198
Life Member# 17
June 15, 2007, 16:45
Brad Cohnthe dial seems to generate some discussion. i've posted the picture elsewhere and had some very interesting and divergent opinions. the good man who revives my watches for me believes the dial is original. although, as someone else has suggested, it would appear that the luminous material has been redone.
the watch has great sentimental value, so i think i'll keep it as is. but i very much appreciate your suggestion!
June 15, 2007, 19:58
Brad Cohninteresting evidence. if it is a redial, it's an old one. it would be a bit of a shock considering that my grandfather, the original purchaser, was reluctant to spend money on it. in fact, he gave it to me because it was broken and he didn't want to spend the $60 to have it fixed.
June 16, 2007, 15:46
Dan MitchellThe dials shown above are certainly correct for the Grant - in Hamilton paperwork it is numbered dial 094. The only alternate appears to have been one with "raised gold figures", which is numbered 093.
DM
June 16, 2007, 17:58
René RondeauThere's no doubt the "Grant" dial has been refinished in the past. Aside from the different style of numbers, the Hamiton name is the wrong font and is positioned far lower than normal. However in the past it was extremely common for watchmakers to have dials refinished when they would do an routine overhaul, which owners typically had done every year or two, just like changing oil in your car. If there was any sign of aging, the watchmaker would refinish the dial as a matter of course. And at that time the typical owner was far less concerned with strict authenticity of design than overall newness of appearance. Yours could have been redone back in the 1940s or 1950s when your grandfather was still using it as his everyday watch, and he had to have it routinely serviced to keep it running. Collectors today tend to be pickier and typically like to have the dials printed with the original pattern.
June 16, 2007, 18:14
Adam M. DubinAlthough I have admired Rolex sports watches since toddlerhood (my dad had three consecutive Submariners, from the '50s on) I had always thought they would be too large for my smallish (7") wrist. I've recently found this to be more a matter of perception than reality. With the proper vintage folded link (rather than solid link) bracelet, they can be quite comfortable. I took the plunge this year, first acquiring a late '60s Explorer 1016, and now this no-date Submariner 5513, ca. 1970.
Adam M. DubinAnother view.
