February 15, 2009, 15:01
Jerry KingNeed a sweep second hand for Bulova....
Hello All....
I have a Bulova mdl. 11AFAC, AUTOMATIC, 17 JEWEL, BLACK DIAL,wristwatch ca. 1962....It needs a second hand....
The pictures are below....
Any help will be appreciated....
February 17, 2009, 20:44
Samie L. Smithjerry try cas-kerr they probaly have the hand you need.
April 15, 2009, 12:30
Jerry KingThanks Samie, I just spoke with the folks at Cas-Ker and they have the parts, actually it's more than just the sweep second hand that I need.... I also need the 4th wheel because the original one is broken also and that is why the sweep hand was missing in the first place....
Thanks for the reference....
April 15, 2009, 15:29
Samie L. SmithJerry sounds like what you need is the sweep second pinion. I will look and see what i have in my parts drawer.
April 15, 2009, 22:04
Jerry KingThanks Samie, but Cas-Ker had the part so I bought the hand and pinion, they are on their way....
Thanks, again....
April 17, 2009, 14:31
Christian E. GaldamesHi all.I am in the same boat as Jerry. It appears that all I need is the sweeo second hand since the pinion is in place.
I'll give Cas-ker a try. Thanks for the supply place name Chris.
April 17, 2009, 16:49
Jerry KingChristian, do you need a phone #....
April 17, 2009, 22:39
Jerry KingHere it is....
513-674-7700
They are in Cincinnati, OH
Here's a link to them:
Cas KerIt is best to call them when you are looking for a specific item....
One other bit of advice, when talking to them tell them you are a watchmaker if they ask you....they only sell to the trade....
April 19, 2009, 18:47
Christian E. GaldamesThank You very much Jerry
July 17, 2009, 17:43
Jerry KingAfter fiddling around with Cas-Ker and others I finally got smart and sent the Bulova to our own Chris Abell and he correctly repaired the watch and while he was at it he also did a COA, new crystal and now it is like a new one....
I have 10 or 12 automatics but this one is the best of the lot as far as the reserve that builds up from wearing the watch for a day....two days later I pick it up and it's still running....most won't do that, they need to be worn each day to maintain the reserve....
See the photo below....
Christian, I hope you have your watch back in shape by now....
July 20, 2009, 08:06
Christian E. GaldamesHi Jerry.Glad to see that your watch came out so nice. I like it very much. As for me. I am afraid it is still the same, largely because I've put it off. Now though, seeing how yours came out, it may be time for me to finish mine.
Again, thanks for posting the update.
