October 30, 2011, 09:20
Chiao ChenChopard: Happy Diamond screwdriver size
Does anyone know what size screwdrivers are used for the screws on the watch band and casing (to remove back case to replace battery) for a Chopard women's happy sport white diamonds (5 diamonds) and blue sapphire stainless watch (style 278893-3006)? Thanks!
October 30, 2011, 09:55
Chris AbellHi Chiao,
If you have the watch there and  its  normal slot type screws  when working on a high value watch take watchmakers screwdriver and grind blades  down to a perfect fit especially important if gold screws or badly damaged (make sure you clean all the dirt away on the case first), case bands there are many types some you need to hold both sides which need a  device with a fixed blade one side and a rotating the other, often a again a normal watchmakers screwdriver, if in doubt don’t risk it take it to a professional much cheaper than the repairs!...
