March 27, 2005, 18:26
Samie L. SmithIllinois Beau Royal question
I have a couple of questions about the Illinois Beau royal watch i am in the process of restoring this watch (this one was given to me)
My questions are is this the right movement for The Beau Royal the ones i can find pictures of in the price guide and a Illinois book on pocket watches shows these as a 15 jewel this one has a 17 jewel 607 movement..
Another question i have is about the hairspring this movement has a round hole in the balance cock for the hairspring stud,,i have 5 other 6/0 illinois movement and the hairspring stud on these is held in place by a small bridge which has 2 screws ...the hairspring is bad i have made it run but was not even close to being in beat and running very fast...
March 27, 2005, 19:41
Rich KuhnSamie,
I think the 15 jewel is correct I don't remember a 17 Jewel vertion, however I will check some of my books and see what I find. Nice watch
March 27, 2005, 20:04
Bryan J. GirouardAccording to Fred Friedberg's book on Illinois wristwatches, your watch came with either 15, 17, 19, or 21 jewel movements. If it is 15 jewel, then it is a Beau Royale. If it has 17, 19, or 21 jewels then it is a Beau Brummel. Apparently the style of case engraving does not indicate the name, rather it is the jewel count that determines which model it is.
You are right about the hairspring stud being different. The earlier 6/0 movements without a grade marking used the bridge with 2 screws, similar to some Gruens. The later 6/0 movements which were marked and had the pillow damaskeening (605, 607, 601) have the circular stud opening held by a screw from the side.
March 28, 2005, 13:50
Samie L. SmithThanks Bryan and Rich for the info.
i have a 21 jewel motor barrel movement serial# 5304613 with second bit at 9:00 postion would this movement be correct for this style of case..
March 28, 2005, 15:57
Bryan J. GirouardYes, the 21 jewel movement would be correct.
