Accutron problem "Click" to Login or Register
I HAVE ABOUT 20 ACCUTRONS. LAST WEEK I REPLACED BATTERIES IN ABOUT 8 WATCHES . ALL 8 STARTED HUMMING AND THE SECOND HANDS MOVED BUT 2 OF THE WATCHES THE HOUR AND MIN HANDS DID'NT MOVE EXCEPT WHEN SET. I JUST SAW A ACCUTRON CLOCK FOR SALE ON EBAY WITH THE SAME PROBLEM . WHAT IS IT? THANKS MARTY ...
Martin Bergman
Posts: 42 | Location: Garrison New York, USA | Registered: December 27, 2005
Picture of Mark Cross
I'm sure one of our Accutron experts will chime in directly, but as I recall, the canon pinion requires particular greasing in the course of servicing, as the hands will tend to bind up after many years of use and no lubrication. You can move the hands manually, but the movement does not have the extra power to move the hands with the dry unlubricated pinion.
It sounds like your watches need servicing, and that particular grease applied to the canon pinion during the COA.
Regards! Mark
You mean I remembered one right, folks?! Eek
WOW! I'm making progress!!!! Smile
HIGH regards! Mark
thanks Mark
i'll try that
marty
Martin Bergman
Is the hands setting mechanism working OK, and returning the hands correctly to the running mode ?
I seem to remember that backset Accutrons have a pin of variable length attached to the back set key to operate the hands when the key is lifted.
DM
