May 13, 2007, 16:17
Philip MenaPls Identify this Hamilton WW.
This is a Stanless steel Hamilton I purchased.
Nothing on the inside of the case not a number or case manufacturer name.   Still I like the case engraving and style.
May 13, 2007, 17:20
Dan MitchellStrictly speaking - not a Hamilton. It is likely to be a Hamilton movement in a replacement case.
When a customer's gold-filled case wore out after long use it used to be possible for your local jeweller to refit the movement in a new, standard 6/0 size, case/dial assembly.
Any Hamilton made case will normally be signed.
Dan.
