January 15, 2011, 15:16
Brad RichardsonMy 169
Hi everyone! I have a 1931 Illinois 169 Model 9 19j pocket watch that I absolutely love! I know that it was made under Hamilton management at the Illinois factory. I was wondering if anybody had more information about this watch. I realize it's NOT a RR grade, but this little feller is so darned accurate. And I love that dial, even though it's a bit dirty and scuffed up. Thanks. Regards, Brad
January 16, 2011, 09:05
Steve MiddlesworthBrad,
Serial number would help ....can you post it?
Steve
January 16, 2011, 09:17
Brad RichardsonSure Steve. I don't know why I didn't post it! It is 5429265. Regards, Brad
January 16, 2011, 12:55
It's a Model 9 from a run of 2000 in 1931 of which there were only 5,190 produced between 1919 and 1932. Not a common watch but not of the mass produced numbers either.
You may notice it has what was called "Friction set" balance jewel setting as it was pressed into the balance arm and not screwed in.
One thing I find interesting about this grade is that there was one run of 90 pieces in 1919 and then never made again until 1930. I seriously doubt the first run had the pressed in jewel. This would be a rare watch indeed.
Yours came out of the third of five total runs and it is a nice looking one with the 24 hour dial.
Steve
January 16, 2011, 13:06
Brad RichardsonThank you Steve. I did notice the friction-fit balance jewel setting. From what I've gathered, this was a Hamilton idea. I don't know why they did it that way. I have a 167 17j movement of the same vintage that I'm going to have repaired someday. It's balance jewel setting looks like a monkey took a screwdriver to put it in! I'm wondering if that piece is hard to find. The dial on my 169 came off of my 167. Haven't seen another one like it yet. Regards, Brad
January 16, 2011, 13:23
Brad RichardsonI'm also curious if there's any way to clean this dial without damaging it. It is a metal dial. Brad
January 17, 2011, 06:47
I believe that friction set jewel was a cost cutting idea. We were still in a depression at the time.
Try searching throug the archives on this site...there is a lot of information on cleaning metal dials here.
Steve
January 17, 2011, 10:28
Brad RichardsonThank you very much, Steve. Will do. Regards, Brad
January 17, 2011, 10:44
Brad RichardsonWell, I've been through the various posts on dial cleaning, and it seems that, whatever I use on it will ruin it. So, I guess I'm just going to have to live with it. Brad
January 28, 2011, 19:12
Eugene BuffardYou might try a magic eraser. The Sangamo clock guy  that is in my are that fixed my Clock used one on my painted dial. It did a bang up job. Just do it slow and around the edge. To make sure it does not remove any of the paint. Call me if you have any questions 618-580-7525
