Illinois Watch Company Research Forum
Mod 1, 18 sz, 11j, KW/KS, HC s/n 187581Go ![]() | New Topic ![]() | Find-Or-Search ![]() | Notify ![]() | Tools ![]() | Reply to Post ![]() | |
Doug, The Sn for your watch puts it at c-1877-78. I don't recall seeing any Deuber marked cases that early. He was making cases, but they were marked "Newport". Maybe others have seen Dueber marked cases from that early. I believe the Deuber marked cases began around 1888 when he moved the case works to Canton. There is also the chance that the original case was damaged about 10-15 years after the watch hit the street and a new case was applied. There is also the chance that the watch sat in storage for 10 years or more before being cased and sold. Tom | ||||
Tom The case s/n is 84617. Does this tell you anything about case. Thanks for the info. Doug | |||
Hi Doug, There are no records for most all case manufacturers. Also, case manufacturers did not do sequencial numbering like watch companies did. When they would start a new case model, they might start a whole new SN string. Your case might be original (the first one to house your watch), but my guess is that your case is a little later than the watch movement. Tom | ||||
