December 29, 2011, 20:44
Allan RopperIllinois vs. Elgin hands
Illinois vs Elgin hands
Are these interchageable on 18s of similar vintage? They look the same but I cannot get the to fit on the Illinois I have restored.
December 29, 2011, 21:42
William D. ShieDifferent manufacturers use different size holes in the hands. If your holes are too small they can be broached to fit, if too large you will need to find other hands
December 29, 2011, 22:17
Eugene BuffardYou can some times tighten the holes with a hole closing punch.
December 30, 2011, 19:48
Jon HartYou can broach the hour hand if it is a just a tad to small, but you do not have a ton of material to work with. However, the minute hand usually gives you more material to remove when compared to the two hands. Thus, allowing you to have a wider range of "tight" fitting hands to widen and make work from your hands stash.
