March 06, 2012, 14:33
Richard PfeifferBurlington info please
I would like to know the model number and any other info. Also need the mainspring part number. Serial number is 3406252 and is on a 21 jewel 16s Burlington.
March 06, 2012, 15:50
Brian C.Hi Richard,
I believe you have a 21j, model 9, open face, lever set, grade 107, year 1918. There are a number of different mainsprings for the 16s Illinois. Your best bet is to measure the spring, including the length.
March 06, 2012, 22:19
Richard PfeifferThank you Brian. The length is 22 1/2 and there are two springs of that length. One has a T end and the one I have has the tabs about 1/4 inch from the mainspring end. I don't know what they call this type of end. I think the spring I need is 47331. This spring fits the model 9 and those with the motor barrel.
March 06, 2012, 23:57
Jared BrinkerRichard-
A model 9 should take one of the three following springs: 47320, 47321, 47322. The difference is the strength (thickness) of the springs. The 47320 is .17mm thick, 47321 is .18mm thick, and 47322 is .185mm thick.
Jared
March 07, 2012, 21:29
Richard PfeifferThanks Jared. There are some 47331 mainsprings for sale on this forum. The only difference I can see, being it is .175mm thick. Would this work?
