October 12, 2010, 20:26
Mike RouseIllinois 60HR. Dial and Hands Question
My only 16s Watch . My question is , are the hands and dial correct for the year ? Hand look like they should be different . And looking at all the Dial info on site , I am still a little confused . My movement is number 5120098 ,case is I believe a First Model. 7865079 . 1928 , correct ? Now should the dial be arrows out , or in ? Any help would be appreciated . Thanks ahead of time ...
October 12, 2010, 20:28
Mike RouseWith Bezel Removed . hands and Perfect Arrows out Dial
October 12, 2010, 20:32
Mike RouseFinal shot . Bunn Special Model . Wadsworth 10kt Gold Filled 7865079
October 12, 2010, 20:45
Steve MiddlesworthMike,
Everything looks to be absolutely correct on your watch, and a fine looking one it is. Even the numbers match up in our database which I will add yours to.
Steve
October 12, 2010, 21:08
Mike RouseWow , that was fast Steve . Didnt even have time to finish my Mountain Dew . I was just wonering because most of the ones I have seen have a Baton type minute hand and the second is round and not pointy . And when did they change from an inny or outy dial . Thanks also for adding it to the data base , I forgot to ask earlier . Mike
October 13, 2010, 20:10
Mike RouseForgot to ask ... How come the 6 is missing . I did notice its a Flat Top 3 , Large seconds bit . Mike
October 13, 2010, 20:27
The "6" was usually only used on the Monty dials. I can't remember seeing "6" used on any of the Railroad style dials.
Steve
October 13, 2010, 20:46
Mike RouseJeez.... Thats what happens when your only using one good eye . I just didnt even think about it .. Thanks
