July 28, 2006, 01:30
Peter S. Balkan161-Mystery?
I recently bought an Illinois 161 and it's a bit of a mystery.
It's a nice looking watch that ought to be a nice addition to my collection.
Here's the mystery. Its Serial Number is 5474454. I'm using that Illinois Watch Project database, which (I'm told) relied heavily on Meggers materials. That database identifies the watch as 1931 production and as a 161-E, with "Elinvar" on the balance cock.
It's not. The watch says "Motor Barrel, Sixty Hour (spelled), 161 on the winding bridge, but it does NOT say "Elinvar" on the balance cock.
I pulled the balance and checked under the bridge. Sure enough.... it is numbered to match the watch's number. But it does not say "Elinvar: the balance wheel is cut.
I have every reason to believe that this is, indeed, a 161 rather than a 161E.
This watch is 100% consistent with a parts-matching non-Elinvar, 161.... except for the information in my database. I don't have a copy of Meggers Encyclopedia. Can someone check their copy or alternate sources to see what this SN brings up?
(Note! I have double checked the serial number under magnification and various lighting as I'm aware that my old eyes have mis-read numbers in the recent past. I'm quite certain that my numbers are accurate.)
P.S. In that same database, I have located a watch with the SN 5474453 (just one off). It HAS an Elinvar balance and the balance cock is so marked. But.... I also located a photo of SN 5480360 (later than mine) which clearly shows an unmarked balance cock and a "cut," bi-mettalic balance wheel.
What gives?
(Here's Don's photo of the movement.)
July 28, 2006, 09:32
Charles R. SidesDon't see a problem here Peter, just another example found, that contradicts the book databases or CDs.
It is examples like this that lets us clean up inaccuracies in the data. Watches were not finished in serial # sequence, and yours more than likely was finished earlier than others in that serial # range.
Charlie
July 28, 2006, 10:59
Peter S. BalkanWell.... you've settled it!
I'm posting a picture of a movement that is the "twin" of my movement, the consecutive serial number.
We've been talking about reuniting "twins" recently on this list (Lindell has a consecutive pair of South Bend watches). Well.... here are consecutive serial Illinois movements, from the middle of the same run..... that are NOT even of the same grade!
Will this hobby ever stop surprising me?
July 28, 2006, 11:04
Peter S. BalkanBefore anyone gets the wrong idea. I am NOT dissastisfied, in any way, with this watch or with the seller.
I have checked it and the movement appears to be absolutely original.
If anything... I am thrilled with the mystery and the explanation. If it doesn't add monetary value to the watch.... it sure added to my enjoyment.
Now.... who wants to sell me that 161E "twin?"
July 28, 2006, 11:41
Peter S. BalkanThe plot thickens, Lindell.
Look at this! Here is SN 5480360, almost 6000 numbers away, and it is clearly a 161 NON-ELINVAR (Balance cock not marked... bimettalic balance).
I think this illustrates exactly what you were saying. This was all in 1931 and the model changes were not "complete" when the manufacturer brought out his new model.
If the customer wanted a 161... that's what he got. Sales were too important.
We also need to know something about the manufacturing process. The balance cocks were engraved "Elinvar" (or not) and the SN was stamped on the back. This indicates, to me, that one of those procedures was done quite late in the manufacturing process. For instance, did the assemblers sit in front of two boxes of balance cocks, either marked "Elinvar" or not? Then, when the orders came in, they merely chose the right one, stamped the SN on the back and attached either an Elinvar or Non-Elinvar balance complete?
July 28, 2006, 12:21
Peter S. BalkanWhat we'd give to be a "fly on the wall" at the Illinois factory in 1931!
Your point is well taken. The companies did not think about their watches as we do.
Case in point. My Dad owned a display business in Chicago. From WWII until its virtual demise, one of his biggest customers was Elgin Watch Co. He made window and counter displays that usually were part of a seasonal promotion. (Before you ask, I don't have a single example of those.)
He MAY have toured the Elgin plant once or twice, but I can assure you that he knew absolutely nothing about watches and could care less. He dealt only with the Advertising and Art Departments.
When we see assembled watches in advertisements, they may well have been selected by folks who simply thought they looked good or would sell well. I think there was a huge gulf between the technical end of the company and the marketing end.
