March 22, 2006, 17:41
Greg ReevesYUCK!
I'm not sure...looks like "lock-tite"?
Literaly had to use pliers to get the hour pipe off. The pivots were somewhat better...they were "locked-up" also.
March 22, 2006, 22:00
Michael CherryHi Greg, might be a good example of what happens to a movement over time that was not disassembled when put into a cleaning tank!
Mike C.
March 23, 2006, 00:00
William Chappellyeah...I think Mike is right. Looks like it's been "dunked". That's why disassembly is critical for proper restoration. I am amazed that people on the MB still ask about cleaning assembled movements. If the person is a newbie, then it's necessary to learn how to disassemble and properly restore the movement. I restored a Herschede 9-tube not too long ago and it had the same green goop in all of the nooks and crannies...any place the person couldn't reach with his cleaning tools. Is it any wonder the clock stopped at about 18 months when you see this photo!
Bill
March 23, 2006, 08:04
J. Bruce WeeksI too just got a Herschede 2 train 9 tube in the shop and barrels behind the main wheel were green from non-rinsed cleaning solution.
TIP - If you can't or won't take it apart, don't dunk it! Especially a piece with internal cavities open to the outside world.
Another problem I see is re-oiling without knowing what was used in the past for oil. If the oils are of different bases (synthetic vs. mineral, etc.) they can react to each other. Some combinations will turn to stone and others to less than water thin.
This is a problem in the bearing industry where mechanics re-grease a sealed bearing unit without dissassembly and cleaning. I've seen it thousands of times when reviewing warranty return parts.
YUCK! is an understatement when you have about 1/2 lb of this 'stuff'.
May 13, 2011, 14:59
William N. McCormickHello - All of the above posts are great. The hour pipe would not, under ordinary circumstances require ANY lubricant insofar as the parts move so slowly that no friction would appreciably occur.
Bill
March 09, 2013, 20:01
Patrick Wallinquote:
re-grease a sealed bearing unit Thats why the bearing is sealed. It's not intended to be re-greased. But I know that their are people that will try.
