November 26, 2007, 23:59
Peter CorkOpen loop mainspring
Hi All,
Could anyone describe for me the correct method of installing an "open loop" mainspring. (If it is different from a normal loop end
P.C
November 27, 2007, 06:38
Greg ReevesIt still should just slip over the post as a normal loop end would. Having said that...there have been occasions(an alarm clock), where I started the tongue over the post, and when the plates were secured after assymbly...that I then wound the mainspring and the tongue and loop would then slip over the post to the correct position.
greg
December 03, 2007, 17:12
Clive DriscollThe real benefit of the open loop is that it sometimes (not always) can be wound directly onto the arbor without having to strip down the movement.
I find the hardeat job can be trying to get the broke spring out.....without stripping down the clock.
December 20, 2007, 20:32
Peter CorkThanks for the helpful replys to all
