IHC Member 376 Watchmaker ![]() |
Hope you folks don,t mind me asking another question... Which mainspring winder is the best i want one that will do both loop end and hole end springs..I have 2 winders and neither work very good,, one of them is downright dangerous,dont want anymore black fingernails.. ![]() | ||
Samie, Whaat winders do you have? Tom | ||||
I have a Ollie Baker style that I like a lot. It has a wide range capabliity for barrel or open springs. Merrits Antiques carries it. www.merritts.com For many years I simply wound springs into barrels by hand, until I lost my grip once and the barrel teeth nearly removed the palm of my hand. OUCH! For open end springs I have a small cast iron piece made just for that purpose (I think they are aluminum today) much cheaper but will not work on spring-in-barrel types. I don't use it much since I bought the Ollie Baker. | ||||
Tom here is the 2 winders i have neither one much.. this one works fair for springs inside a barrel ![]() | |||
this one is a dandy for mashing fingers ![]() ![]() | |||
I will second the Ollie Baker recommendation. | ||||
Sammie, Click the link below to look at a mainspring winder that Joe Collins built. I think he has made some improvements since this design. I was impressed and will someday build one for my own use. https://ihc185.infopop.cc/eve/ubb.x/a/tpc/f/5146029761/m/3641095821 Best Regards, Dick Feldman | ||||
S.S.! Throw that little cast iron thing away. Buy an OLLIE BAKER! Costs a little more. You get what you pay for. In this case - you do. I have never heard a dissenting opinion on an Ollie Baker. KERTHUNK! Thank you. Scottie. Howard S. McElroy | ||||
Samie: I use a Webster and I like it fine, but I do find the Ollie to be safer. gp Grant Perry | ||||
Hi Samie, This URL will take you to a detailed description of how to use the Ollie Baker winder. ftp://ftp.webcom.com/pub/z4murray/repair/olliebaker.doc It was this description that prompted me to build my own. I just couldn't see having to wind with one hand while holding the increasing pressure with the other. So Scottie you have at least one dissenting opinion. JMO Joe | ||||
Thanks everone for the information i took a look at the links posted and they were a big help. Joseph nice job on the winder you made ,great job..i am going to buy one but i may try making one also.. I have a couple of small 3 jaw chucks that came off a small metal lathe i could use... I spent a lot of time running a metal lathe and milling machine back in my working days so maybe i can whip up something that would work.. ![]() | |||
Samie, Look at my post 'I Did it Again' under Tools & Misc. That is about a wooden model I came up with that works very well. I have made a video showing its use and have drawings of it that I can email. If you would like a copy of the video and/or the drawings send me a PM with your email and mailing address. This offer of information goes for anyone interested in this information. Joe | ||||
Joseph thanks for the kind offer i sent you a email.. ![]() | |||
Joseph i sent a email to nofnf@sbcgobal.net and is was sent back by my server ..did i get your email right.. SAMIE | |||
Samie, That would be N zero FNF. The zero throws lots of folks off. Try it again. Joe | ||||
IHC Life Member Moderator |
I have been working with using a variable speed drill to wind the spring. One needs a slow speed, and I'm trying a "cage" for it to be wound inside. Perhaps it will work properly when I'm completed with the modifications, but so far it is quite a good method. Moses Gingerich Waxhaw NC | |||
