December 12, 2007, 21:52
James G. FischerTick, Toc-Toc sound???
Help! I have been learning clocks for only one year now and am a new member to this group. I have run into something I can't find in any of my reference materials. I am working on a Decor brand wall clock (est. vintage 60's to 70's???). It is a strike and time clock with a German "Davis" movement. It looks just like the Hermle's I've worked on in the past. It is a spring driven pendulum clock with a friction fit verge to set the beat (deadbeat).
I have it set so that it's keeping good time and chiming well, but it has a distinct "Tic, Toc-Toc, Tic, Toc-Toc" beat. I have tilted the clock to both sides in smallincrements, and cannot find a spot without this sound. My Micro-set beat error detection equipment senses the goofy sound, too, and makes it impossible to use my trusty Micro-set instrument to set the beat error as close as possible.
Visually the drop of the pallets seems to be typical and even. I can't find the source of the stray sound, and it doesn't seem to be interfering with the functioning of the clock. Comments from all helpers are welcome!
Jim Fischer
December 12, 2007, 21:54
James G. FischerCorrection - make that a "strike and Chime" clock in line two.
Jim
December 12, 2007, 22:14
Richard MoreyJames, Others are much more experienced than me but may I suggest that you remove the movement, put it on a stand, ensure it is level and then watch it work. If you have old eyes like me you will need to have good light because you want to watch the escape wheel and the verge under magnification. You may have to watch it for a little bit while you listen but my guess is that you will see an abnormality in the way the verge and escape wheel interact.
Let us know what you see and hear.
Rick
December 12, 2007, 23:45
Tom SeymourRichard is probably right. Another place for noise is a "slap" that can develop when there is too much room in the crutch for the suspension wire. It slaps the side of the crutch and makes a sound. That situation also robs a lot of power and is often a cause of a clock stopping.
December 19, 2007, 11:40
James G. FischerThanks, Rich and Tom. I wil be getting back to this project only after the first of the year. I will let you know how it goes.
Jim Fischer
December 19, 2007, 11:41
James G. FischerSorry - make that "Rick" and Tom.
Jim
