August 31, 2015, 12:46
Larry BuchanCANADIAN Private-Label Watches
Movement close-up it needs a regulator spring.
September 06, 2015, 14:33
Larry BuchanIllinois 16 size, 17 jewel, Serial No. 1311261, Manufactured 1896 Grade 175 Canadian private-label, double sunk, Gothic numbers dial marked Davis & McCullough in script, and SPECIAL, Getty model 5 movement marked "Davis & McCullough Hamilton, Ont. Special" Cased in a 20 year yellow gold filled Fortune case made by the American Watch Case Co. of Toronto, Ontario.
September 06, 2015, 14:37
Larry BuchanDial with bezel off
September 06, 2015, 14:40
Larry BuchanMovement
September 06, 2015, 14:44
Larry BuchanMovement close-up needs regulator spring
September 06, 2015, 14:46
Larry BuchanAmerican Watch Case Co. Trademark in Case Back
September 06, 2015, 22:23
Larry BuchanHamilton, Ontario population 721,000, the third-largest city in Canada, it is a port city on the West end of Lake Ontario, it is heavily industrialized. The Toronto, Hamilton and Buffalo railway ran from 1894 to 1987. It never reached the other two cities in its name, the railway was originally chartered in 1884 by the Ontario Legislative Assembly to run from Toronto to the International Railway Bridge connecting with local lines to Buffalo. The original corporation was unable to complete the line before the original charter expired. In 1895, the Canadian Pacific Railway and the New York Central Railroad bought the TH&B. The TH&B was jointly owned by the CPR and the NYC for several decades. NYC and its subsidiaries (Michigan Central Railroad, and Canada Southern Railway) owned 73%, while the CPR owned the other 27%. It never built into Toronto or Buffalo, but used its parent companies trackage to reach the two cities.
September 14, 2015, 13:01
Larry BuchanWaltham 18 size, 21 jewel, Serial No. 17118504, Manufactured 1908, Grade 845, Model 1892, Canadian private-label, double sunk Bold Arabic 24-hour dial marked Riddell & Vinet, Point St. Charles. (Montréal, Québec) Movement marked A.W.W. Co. Waltham, Mass 845 Adjusted 5 Positions.
September 14, 2015, 13:04
Larry BuchanDial with bezel off.
September 14, 2015, 13:07
Larry BuchanDial close up.
September 14, 2015, 13:09
Larry BuchanWaltham "845" movement.
September 14, 2015, 13:12
Larry BuchanWaltham "845" movement close-up.
September 14, 2015, 13:17
Larry BuchanWaltham is cased in a American Watch Case Co. of Toronto Ontario, it's a screw back and bezel type, photo of case back.
September 14, 2015, 13:19
Larry BuchanInside of the case back.
September 14, 2015, 13:25
Larry BuchanAWC Co. case trademark
October 11, 2015, 12:44
Larry BuchanNice double sunk bold Arabic 24-hour dial.
October 11, 2015, 13:09
Larry BuchanHoward 16 size, 19 jewel, No. 5. Serial No. 1108641 Manufactured 1912.
October 11, 2015, 13:24
Larry BuchanBridge movement close-up marked 19 JEWELS, No. 5. E. WATCH CO. BOSTON USA, with arrow through triangle. PATD'08. EXTRA ADJUSTMENTS FIVE POSITIONS TEMPERATURE
October 11, 2015, 13:33
Larry BuchanDouble hinged back and hinged bezel American Watch Case Co. (of Toronto, Ontario) 14 karat yellow gold case. AWC Co. gold cases are fairly scarce, I have another one in my collection with a Waltham Vanguard 16 size, 23 jewel, wind indicator.
October 11, 2015, 13:36
Larry BuchanAWC Co., 16 size, 14K case trademark
October 11, 2015, 13:40
Larry BuchanCase has an inscription on the inner lid that says "Presented to J.A. INNES by his REVELSTOKE FRIENDS May 28th 1919.
