In Search Of Seth Thomas
May 10, 2012, 07:41
Dr. Debbie IrvineIn Search Of Seth Thomas
Simply gorgeous!
May 13, 2012, 21:23
Eric UnseltThanks Debbie.
The chart below is the 1904 catalog showing serial numbers by Model assignment. The
red arrow shows the 200,000 numbers blocked out for the Model 5. Remember, by this point the company had been making watches for nearly 20 years, and the serial numbers had yet to reach the million-mark. In another 10 years the company would stop pocket watch production entirely, so I question if they actually produced the 3 million watches they were supposed to have made.
May 13, 2012, 21:26
Eric UnseltThe
blue arrow in the above chart identifies the run into which this next watch falls. Notice that from SN 10,000 where the Model 1 leaves off up to SN 100,000 there is only Models 2 (hunter), 3 (3/4 plate OF), and 4 (KW OF).
My thanks to our own Jon Hart for this example, a gilt Model 2, SN 88645:
May 13, 2012, 21:27
Eric UnseltAnother interesting lever-set 16-jewel movement with no center jewel on the dial side:
Note the Adjusted marking on the pillar plate next to the balance.
May 13, 2012, 21:31
Eric UnseltProtected by a fantastic gold-filled hunter case supplied by IHC185's own Rob Jones:
May 13, 2012, 22:23
Jon HartEric,
Is that the movement you purchased from me on IHC?
WoW!
May 25, 2012, 14:07
Eric UnseltYes Jon, and thank you - it now has a new dial, re-blued hands, and a period-correct hunter case.
Below is a 1909 advert for the Grade 36 Model 8:
Again note the half-headed case screws and the lack of a dust band.
May 25, 2012, 14:10
Eric UnseltThe 7-jewel pinstripe New Eagle movement was one of the most common of the lesser grades.
Thanks to our own Andy Schwartz for this example:
May 25, 2012, 14:12
Eric UnseltFronting it is a very unusual metal Arabic dial:
June 13, 2012, 22:19
Eric Unselt-
June 13, 2012, 22:22
Eric UnseltHere is yet another variant of the Grade 182, and this time it's circles-and-rosettes with a center checkerboard:
June 13, 2012, 22:23
Eric UnseltFronting it is the black-only Arabic Gothic dial with open morning-glory hands:
June 13, 2012, 22:24
Eric UnseltFully protected by an Arm & Hammer case:
July 01, 2012, 17:07
Eric UnseltThe rarest Maiden Lane of them all was the 21-jewel variant. Available in two separate runs of 20 and 60, for a total of 80 ever made, the earlier patterns had no jewel count, some runs simply had the letter "J" after the "21", while the later runs had the word "jewel" spelled out.
July 01, 2012, 17:08
Eric UnseltFronting it is the standard Arabic dial with matching spade-and-poker hands:
July 01, 2012, 17:09
Eric UnseltAll wrapped up in a stunner of a Philadelpiha case:
July 03, 2012, 17:40
Eric UnseltAn ad from the 1908 catalog, showcasing more of the Model 8:
July 03, 2012, 17:42
Eric UnseltIn the above ad this watch would've fetched a mere $6.65 back in the day:
July 03, 2012, 17:44
Eric UnseltAnother two-tone 17-jewel pattern Model 8 from the incredibly prolific design engineers at Seth Thomas:
July 03, 2012, 17:45
Eric UnseltWrapped up in a lesser 10-year Supreme case:
August 07, 2012, 22:16
Eric UnseltAn ad for Models 8 and 9, open-face and hunter, respectively, showing an 11-jewel variant. It's a standard 7-jewel watch with 4 extra jewels in the top plate only.
August 07, 2012, 22:17
Eric UnseltHere is an example of an 11-jewel Model 8 in a two-tone pattern:
