Our Exclusive "Timekeepers Photo Gallery"
IHC185™ "Timekeepers Photo Gallery"
PICTURES OF THE HUNLEY WATCH...Go ![]() | New Topic ![]() | Find-Or-Search ![]() | Notify ![]() | Tools ![]() | Reply to Post ![]() | |
| IHC President Life Member |
2 ![]() | |||
3 ![]() | |||
4 ![]() | |||
5 ![]() | |||
6 ![]() | |||
7 ![]() | |||
8 ![]() | |||
9 ![]() | |||
10 ![]() | |||
11 ![]() | |||
12 ![]() | |||
13 ![]() | |||
14 ![]() | |||
Hi to all, Just recieved latest "Bulletin". Article states, Able to identify the maker, Why the secrecy?, why not tell us straightaway,who?.I realise It's the case maker that's been identified in all probability,but I can't understand the logic of keeping secrets. GED. | ||||
You're right Ged! At the top of this thread we said "...another similar Tobias..." would be displayed but evidently some of the others want an "air of mystery to surround this old beast. | |||
Among other fascinations it was a 137-year experiment in the protection provided by a case with hinged covers; making me wonder how a case with screwed-on covers (first described as far as I know in Fitch's 1879 patent) might have fared under similar circumstances. | ||||
Stu, I can only surmise that with some types of Screw Back and Bezel style of case the threads may have siezed thereby making it impossible to open blob of metal. At least with a hinged case they were able to pry it open. The fact this case was evidently gold would also be an important factor. After all, look what happened to the metals used in the movement. What do others say? Lindell | |||
| Watch Repair Expert |
The thing to consider when a watch (or anything else) is submerged in water, is the pressure of the water itself. Water pressure increases at a rate of about half a pound per square inch per foot, so that an object submerged in 30 feet of water, will be under about 15 psi of pressure. According to "Boyle's Law," since volume and pressure are inversely proportional, as the pressure of a gas (such as air) is doubled, its volume will be halved. Ambient air pressure on the surface of the Earth is doubled with each additional increase in water depth of 33 feet, so that the space occupied by air inside an unsealed container will be reduced to 50% of its surface volume when submerged in 33 feet of water. In other words, if there's nothing to prevent the entry of water under a force of about 15 psi, a watch will become half filled with water at a depth of 33 feet, and that's assuming that none of the air originally inside escapes! In my opinion, it wouldn't have made any difference what type of case the "Hunley" watch was in. Unless it was housed in a specially designed case that would have been FAR beyond the technology of the day, the result would have been essentially the same after 137 years at the bottom of the ocean. =========================== Steve Maddox President, NAWCC Chapter #62 North Little Rock, Arkansas IHC Charter Member 49 | |||
Thank you Lindell! It's a joy to see this historic watch up close. If you don't mind, I have a few questions: 1. Is the dial silver? 2. Is this historic watch a real Tobias or a Tobias fake? Thanks, Greg. | |||
Thanks Greg! Frankly I know little about the watch other than what we've all read and now can see. My bet is that dial was once a beauty. The gold case has held up and according to our IHC 185 Watch Expert Steve Maddox this is a genuine Tobias which I'd think would be a pretty good watch. We are really proud to have been chosen to show these amazing images! Lindell | |||
