February 02, 2014, 11:07
Tom BruntonHelp needed to ID these 3 items
I bought a partial estate last week and these were in a box of parts,any idea what they are???
February 02, 2014, 11:08
Tom Brunton#2 base diameter 1 1/8" note-the perspective is wrong and it actually measures 1 1/8" across diameter of the base
November 28, 2014, 19:50
Patrick WallinBoy we should get together. I have a lot of items, that I have no clue as to what they are.
Perhaps we should start a what is it? Lots of members could learn a lot from it.
November 28, 2014, 20:06
Lorne WasylishenThe first 250 pages of this catalogue contain lots of thingamadoies and whatchamcallits.
J.H. Purdy & Co. 1899November 28, 2014, 21:09
Roger StephensI think the first item is a leg prosthesis for a stork.
Roger
April 06, 2015, 15:45
David E. Booth, Jr.I have seen drawings for making tool #1 in high school metal shop class. I suspect it is for separating some sort of thing from a tapered shaft. Number 2 looks like the base for my lawnmower blade balancing tool. It has a stepped spun aluminum cup, to fit different sized center shaft holes, that sits on top of the pin. After sharpening the blade, it is rested on the appropriate cup, and whichever side is heavier gets a little more grinding.
April 06, 2015, 19:27
Thomas M. CusackI'm going with clock tools the first on ,I have seen just forgot where ( I think some clock show in Ma. a few years ago )
April 10, 2015, 22:07
David E. Booth, Jr.Mr. Cusak's reply finally jogged my memory. It is calld a "crows foot" and is used to hold thiongs like the top part of a lantern pinion while a punch is used to drive the arbor down, thus freeing the individual runners.
April 21, 2015, 00:18
David E. Booth, Jr.If you were into small and really detailed scale model cars, it would probably make a nice ball joint separator, too.
April 21, 2015, 08:52
Billy KuhnThe one on the right looks like a support for the balance cock so you can work on the hair spring.
