November 23, 2006, 10:00
Naoki Imaizumiquartz watch analyzer advice wanted
I am looking to get a cheap quartz watch analyzer which will test average consumption, operation of the grounding switch, lower working voltage limit, verification of impulses from the IC, resistance of the coil, coil insulation. What would you recommend? Any comment is greatly appreciated!
November 25, 2006, 09:55
Tim HillsIf your handy with the soldering iron and don't mind taking the time you could make one. There are instructions in "Questions & Answers in Quartz Watch Repairing" by Alice and Buddy Carpenter.
The AWCI has copies.
November 30, 2006, 17:50
Naoki ImaizumiTim,
I thank you! I got the book and am reading. The idea of the variable voltage supply kit seems to be a good idea.
Appreciated your help.
December 18, 2006, 11:39
Naoki ImaizumiTim,
I am still reading...and getting rather confused with so many attachments mentioned in the book.
What do you use yourself?
December 18, 2006, 17:12
Tim HillsNaoki,
I made and use the one in the book your reading. It might take a little getting used to. Initially, I had to take it slow so I could understand what I was supposed to do and what I was supposed to attach the clips or touch the probes to.
Another book/pamphlet that helps is Seiko's "Technical Guide. General Instructions. Analogue/Digital Quartz". They are not easy to find but turn up on Ebay every once in a while. Also, Dashto.com occasionally has them in his book section. It helped clear some things up for me.
Tim.
December 21, 2006, 20:43
Naoki ImaizumiHello Tim,
Thanks for your input. I guess I need to be more patient...and will try to get the Seiko guide which you recommended also.
Many thanks.
