June 23, 2010, 16:09
Adonya OurshalimianSouth Bend 293 Question
I just picked up this grade 293. According to the serial database #438610 puts it in the first run for this grade.
However, after looking through the literature I couldn't find anything on the dial. Is it period correct for this movement. I would think being a "Railroad" grade the 293 should have a dial with arabic numerals. Unless the original buyer opted for this style?
I'd love to hear what others have to say.
I apologize for the terrible photos. I haven't had time to take new ones yet.
June 23, 2010, 19:20
Tony DukesAdonya,
This same dial fronts my SB 291--#384521.
Tony
June 24, 2010, 22:25
Jared BrinkerI checked my 293's from the same run and my 292 from the run. the 293's have the same dial, my 292 has a metal dial, but i'm sure it is not original to the watch as the case has been changed also.
Jared
June 28, 2010, 03:15
Adonya OurshalimianThank you Tony and Jared for your replies. It would appear that this is a correct dial then! I can now breathe a sigh of relief.
July 13, 2010, 08:24
John ScottMy grade 293 is 505155 and it also has the same dial. These are a pretty nice watch.
July 13, 2010, 15:42
John J. Flahive IIII need to add this one to my wish list.
Nice watch!
John III
August 12, 2010, 12:14
Frank KusumotoAdonya,
For watches produced by SB in 1903 (per the online database) I have recorded 52 examples. Two have Arabic dials and a font that is found in the twenties and are certainly replacements for the original dials, or some other event. One has a metal dial that looks like a repo dial. All the rest are Porcelain, Roman #'s, have red numerals above the hour marker, some are single-sunk, some double-sunk, and they all have that type of heavy Gothic script for the company name. The exception is some of the dials for the 6s movements that have a clean style that looks like "Arial Bold Italic" used for the South Bend name.
My opinion is that the movement and dial of your watch is likely to be an original combination. Furthermore, it is likely to be an original combination because that pairing appears to have been the norm during 1903-1904, while the South Bend management and senior staff (like Higginbotham) were deciding what changes were to be made.
Best regards,
Frank
August 12, 2010, 19:00
Adonya OurshalimianFrank,
Thank you for your in-depth analysis. I'm always blown away by the knowledge people like you have on these forums and am trying to learn as much as I can about South Bend as they are my favorites!
Thanks again!
