January 08, 2015, 13:50
Curtis MeloyResurrecting a 229 Studebaker
Hi all, I've been collecting watches (wrist and pocket) for several years now and just found this site as I was hunting a pallet fork for a 229 movement. I had questions about interchangeability, but I believe the pallet fork bridge in the 229 has a cap jewel and I am not nearly educated enough to know how that affects interchangeability. Any help with this would be wonderful!
I currently own 2 south Bend pocket watches, a 229 and a 217.
January 08, 2015, 17:18
Rafal WolerHi Curtis,
Please check following link
http://library.ihc185.com/SB/index.htmYou can find there a lot of useful information about South Bend watches, also parts catalogues you might be interested - there are information in which grades parts were used.
Rafal
January 08, 2015, 21:39
Curtis MeloyWow, great information there, thanks for directing me to it!
So, it appears the pallet fork is not interchangeable with any other grade except maybe early 223's, right? Probably not a great chance of finding a relatively inexpensive parts movement.
Any ideas on where I could get a pallet fork otherwise? Thanks again for the help.
January 09, 2015, 07:21
Rafal WolerWhat is serial number or year of manufacturing of your 229?
January 09, 2015, 10:00
Curtis MeloyI believe it's approx 1910 sn.622484.
January 09, 2015, 18:23
Rafal Wolerplease check
http://library.ihc185.com/SB/1917/Image75.jpglook for 37242 as your serial number is below 627901
You have said that you have grade 217, its worth to check if those forks can be exchanged.... and if answer is yes, you would need a donor watch.
You may also try
http://www.watchesbyhourminsec...ID=1289&CategoryID=6 there is always a chance
Rafal
January 10, 2015, 02:21
Bila WirriganwaltersHi Curtis,
The serial number you have given is for a 21 Jewel watch which has cap jewels, best bet for a similar fork would be a Grade 227 as this is also a 21 jewel watch. The 217 is only a 17 jewel and does not have cap jewels, the fork from it would be a suitable replacement for a Grade 223 Studebaker, not the Grade 229.
Cheers,
bila
January 11, 2015, 18:08
Curtis MeloySo, I'm on the hunt for a donor 227. Thanks for all the help and advice. I'll let you know how it turns out.
Wish I knew more about the forks in that link. I'll try to contact them to see if they have any more info.
January 11, 2015, 18:57
Bila WirriganwaltersJust thought I would let you know that there is a good chance that a fellow member here might have the part you are looking for.
To access the "Internet Horology Club:
sales & wanted to buy" part of the forum board you need to
become a member.
This is an easy exercise to accomplish and only costs $12 for a yearly membership (if you haven't already done so), very cheap indeed for access to the amount of knowledge available here from other members and the research forums, this low fee also helps contribute to keep the Club afloat.
Bila
