Today I did my first Rockford. It’s basically the same as any other watch but there are a few differences. I found that the winding section has just enough of a difference to keep you on your toes, yet it is simpler than Waltham or Elgin. It just lines up differently.
The bridges are all great in the way they line up, although I did have a problem getting the escape gear to fall into the hole. The barrel bridge has parts on it that differ from the ordinary. I kept checking under the microscope for problems and after an ultrasonic cleaning I could still see dirt. At one point I found a piece of skin from my finger about to go under the bridge on the 4th wheel.
Micro Scopes are great for finding problems you can’t otherwise see and also for finding cracked or shattered jewels, bent teeth and any thing else you can put under it.
However due to the skin find, I will now always use a Microscope to continue checking things out. Also some of you may not wear gloves, but due to finding skin on the 4th wheel I will now always wear them.
