Question about Waltham Fork (Answered!)
https://ihc185.infopop.cc/eve/forums/a/tpc/f/3426047761/m/9803926387
October 16, 2014, 17:53
Patrick Wallin
Waltham, 12s, OF, Grade 210, Model 1894.
Which way does the fork go? Pin up or pin down.
Pin up does not seem to work but then I am not sure I have the right fork. It fits and the pallet jewel in on the tooth of the Escape gear but it is not lining up between the banking pins. Possible wrong fork? Pin down seems to be an absolute no go.
October 16, 2014, 19:57
Rob Carter
Patrick,
If it is a single roller typically the pin should be up. Double roller usually the pin is on the bottom of the pallet when installed.
Rob
www.pocketwatchrepairs.net
October 17, 2014, 11:35
Patrick Wallin
Thanks Rob,
That's what I needed to know.I had forgotten about the difference between the single & double rollers.
