March 21, 2008, 10:41
Bob WilliamsSize Code , Winding question .....
I posted this question on the pocket watch page , they suggested I put it in the technical group so here it is ......
I am still not sure about what the s after the size means 16s.
I also have another simple question ( I hope ). I have acquired several reasonably priced (cheap) watches. Most of them do not work but I have two that do. They are all Elgins . The question is ..... how tight and how often to wind them. The one runs really well but I want to be careful not to over wind. The other winds up ok but requires a tap to get it started. It also seems that if I wind it tight there is a slippage of some kind and the tension goes out of the winding. when I wind again the tension increase and then slips again. I assume that this means the center of the main spring is not properly anchored or there is some sort of over winding protection in the watch.
The more I learn the more questions I have. Thanks again for everyones time and attention.
March 21, 2008, 14:08
Lawrence FureThe s in 16s is for size. 12s = 12 size,18s = 18 size.
I'm sure the mainspring is broken in the watch you are having winding troubles with. If you don't want to mess with these just send them to me and I can fix them for you.
March 22, 2008, 04:56
Frank KusumotoLawrence, since you're offering, is the service free?
March 22, 2008, 09:54
Lawrence FureMy advice is free. Labor cost is a little higher.
March 22, 2008, 16:02
Bob WilliamsThanks Lawrence I'll keep that in mind.
