A recent wristwatch purchase unfolded an interesting problem I've not seen before. The watch can be set, wound and runs great in an upright position. When I wear the watch, the hour hand "slips" for a lack of a better word, showing a different time. Easy fix? What does it entail? Stephanie O'Neil | ||
I would hazard a guess as maybe the hand(s)need tightening or the canon pinion may be loose and need to be tightend. Good Luck, Earl | ||||
Perhaps the hour wheel slips out of gear because a dial washer is missing to hold it in place. If there is enough space behind the dial I should think that would happen quite easily... especially swinging around on your wrist. Also, if the watch were laying flat, it might operate normally because the hour wheel would re-engage, by its own weight, into the proper position (meaning the hour hand would start functioning normally though probably at the incorrect time). If that is the problem, then a simple installation of a new dial washer over the hour wheel will solve the problem. All you would have to do is remove the hands and dial, put it in, then reattach the dial/hands. So, yes... an easy fix if I'm correct. I hope you post what the problem is when you find it. It would be interesting to find out for sure. Tim. | ||||
My Guess is, the hand needs to be tightened. Brian C. | |||
