Balance Jewels ? "Click" to Login or Register
Picture of Donald E. Jones
posted May 17, 2007 13:00
When buying jewels, which balance jewel is the upper, and which is the lower one ?
D. E. Jones
Posts: 73 | Location: Sulphur Springs, Texas USA | Registered: June 29, 2006
posted May 17, 2007 13:58
I think lower balance jewels are the ones on the pillar plate. The upper jewels are on the bridge side.
Tim.
Posts: 95 | Location: Pembroke Pines, Florida USA | Registered: January 16, 2006
IHC Member 376
Watchmaker
Picture of Samie L. Smith
posted May 17, 2007 19:50
Tim is correct upper is the one in the balance cock on some watches the upper and lower balance jewels are the same..
posted May 18, 2007 13:57
Thanks!
D. E. Jones
posted May 18, 2007 14:42
Donald, I don't know how much experience you have in replacing balance jewels, I know I only have experience limited to Waltham Pocket watches 12S to 18S. The points I found you need to observe are:
1. the hole size in the jewels match the pivot size of the staff. Usually 0.01-0.02 larger in the jewel. I test fit the jewels on the staff pivots before I fit them to the cock or foot as sometimes they don't always arrive as ordered & you can spend a lot of time chasing a staff binding in a smaller than ideal hole that wasn't part of the original problem.
2. you need to match the thickness of the original jewel (if in a setting) being replaced. If you get a jewel that is close you can "adjust" the cock via various means to get the correct amount of end shake on the staff. If you've replaced the staff as part of the repair, you'll have to check/adjust the endshake in any case.
Hope this helps.
Regards, Phil
Posts: 28 | Location: Mosman, NSW Australia | Registered: January 02, 2007
