April 29, 2006, 18:49
Mark NathansonNeed A 17mm Female Spring?
I am looking fora 17mm female spring for a watch. If someone has or can lead me to where I can get one it would be very much appreciated, thanks.
April 30, 2006, 18:15
John D. DuvallMark,
Do you need a 17mm long mainspring? What make and model of watch do you need it for?
April 30, 2006, 19:06
Mark NathansonIt is for a pin to attach a watch band to the watch. It has permanent stubs pins on watch. It is an open end spring/pin that is 17mm long. It is for a Webster watch by Hamilton. Thanks for reply
April 30, 2006, 20:43
Tom HuberMark, You are wanting a "spring pin". These are readily available at any jewelry store or mall kiosk that fits watch batteries and watch straps.
April 30, 2006, 22:05
Mark NathansonThanks for reply. I tried 2 around me and they do not have any. Would you know any that I can order on line?
April 30, 2006, 22:47
Tom HuberMark, I saw from your post on the green board that this spring pin is different than the norm. I don't not know specifically of a site where you could order from. Some of the Hamiton collectors here might know.
May 01, 2006, 04:19
Brian C.Mark,
Do you have a picture of the spring you need?
Brian C.
May 01, 2006, 11:58
Dave ArneyMark,
It sounds like you need a 17mm female spring bar. This type of bar has holes on the ends to fit pins on the case lugs, rather than the usual arrangement which is the other way 'round. Have you checked the Jules Borel catalog? I think part 417-B, 17mm female spring bar, on p. 50 of their horological catalog is what you need. If not, they have 6 pages of spring bars with illustrations.
catalog page -Dave
May 01, 2006, 17:37
Mark NathansonThanks for the information. That is exactly what I needed. I thought it was a hard item to find. Appreciated.
May 01, 2006, 23:38
Cary HurtMark,
Send me an e-mail. I have some vintage ones that you can have.
Cary
May 01, 2006, 23:53
Mark NathansonJust to make sure we are talking same item. I am attaching a link for item. It is the high grade spring bars in the upper right corner. If you have one 17mm, I will try to cancel order. Could you let me know if it is the same? Thanks and appreciated.
http://www.julesborel.com/images/horological/page50.gif
