July 05, 2020, 16:25
Gary E. CochranHamilton staff
Has anyone replaced the staff on a 7 jewel Hamilton...If so what staff did you use...It seems like a Hamilton 18 size single roller staff is to short...
July 05, 2020, 18:37
Brian C.Gary, what's the serial number of the movement?
July 05, 2020, 20:57
Harry J. Hyaduck Sr.Gary I only know of 4 Hamilton 18s 127LC, 127SC, 126LC and 126SC. It would not surprise me at all that the 7j and 11j models may not be documented or that yours could have been modified with hole different hole and cap jewels. I know all the very early 5 digit and less serial numbers jewels are different sizes than the serial numbers after 100,000. Good luck my friend I wish I new the answer.
Harry
July 06, 2020, 08:04
Gary E. CochranBrian serial is 2221....All the Hamilton 18 size single roller staffs are to short...
July 06, 2020, 08:09
Gary E. CochranHarry I was thinking maybe someone had replaced a staff on one of these and maybe knew a sub since none of the regular Hamilton single roller staffs don't seem to be long enough....Take care my friend...
July 06, 2020, 10:39
Roger J. NolfeI can make a staff, however it would be quite expensive and would be quite awhile before I could get to it.
Roger
July 06, 2020, 16:55
Gary E. CochranRoger thanks for the offer....I have a fellow that is going to make the staff for me, I was just trying to come up with a staff for the watch so I wouldn't have to pay to have one made....You are right it is expensive to have one made...
July 06, 2020, 20:58
Bila WirriganwaltersDo you know how much too short the standard Hamilton 18 size staff is Gary?
July 07, 2020, 09:07
Gary E. CochranBila if I remember right the fellow that is restoring the watch for me told me the standard Hamilton staff is 5.44mm long and the one needed should be around 5.7mm....I think he is working on one now for me....This watch had a lot of problems and is going to be pretty expensive to have restored....O well its only money right...LOL...Do you still need the 992 pallet....
July 07, 2020, 18:14
Bila WirriganwaltersWould love to know the complete dimensions Gary, from memory there is a substitute you can use that works quite well. I just would like to double check dimensions, as this was passed on by a Watchmaker some years ago to me and is floating around in some of my notes I have stored away.
July 07, 2020, 18:42
Bila WirriganwaltersPallet is still needed if you find one, I'll even take a parts movement if need be, cheers.
