making eccentric banking screwsGo ![]() | New Topic ![]() | Find-Or-Search ![]() | Notify ![]() | Tools ![]() | Reply to Post ![]() | |
Does anyone know a method for turning eccentric banking screws? I have been able to make them in a standard screw-making manner, then bending the banking pins to achieve the eccentric effect, but surely there has to be a trick to actually making one properly. Any thoughts? Mike Miller NAWCC Member# 154831 NAWCC-IHC Charter Member# 27 | |||
| Watch Repair Expert |
What Doug suggests would work fine, but the job could also be accomplished using a three or four-jaw lathe chuck. With a four-jaw chuck, the jaws can be adjusted off center to allow the proper offset. With a three-jaw chuck, a small spacer can be placed between the work and one of the jaws to achieve the correct offset. Personally, I'd use a three-jaw chuck and spacer, which should produce relatively uniform results, but there's more than one way to skin a cat! ---------------------- Steve Maddox President, NAWCC Chapter #62 North Little Rock, Arkansas | |||
Thanks Doug and Steve! Both sound like very good ways of accomplishing this. Alas, I don't have a jawed chuck for my lathe (hint... anyone looking to sell one Mike Miller NAWCC Member# 154831 NAWCC-IHC Charter Member# 27 | ||||
| <Doug Sinclair> |
Mike, I have used Steve's four-jawed chuck method of turning eccentric, adjustable bearings for a tower clock anchor, and it works well. If there is such a thing as a four-jawed chuck small enough to turn something as small as a banking pin, I dont have one. As I said in my original answer, I've never used that method to turn an eccentric banking pin, so I look forward to your report as to whether it will work or not. Doug S. | ||
