Fixing Bezel threads on 18s pocket watch caseGo ![]() | New Topic ![]() | Find-Or-Search ![]() | Notify ![]() | Tools ![]() | Reply to Post ![]() | |
I have a Waltham 18s pocket watch case that has seen some rough time, but is generally quite serviceable. When I got it, it was impossible to unscrew the bezel, but I worked out that issue and got the bezel off. Now I am looking for advice about how to get the threads cleaned up so the bezel will screw on and off nicely. I have done my best to clean things up, as well as inspected for damage (none is obvious). It oughta work, but after maybe a turn and a half starts to get really tight. | |||
| IHC Member 1555 |
Hi Tom, It may pay to check the serial numbers on the case body and the bezel to make sure they are the same. Thats if you haven't already done so. Regards, Bila | |||
Thanks for the tip. With the watch in hand right now I see the back (which screws on nicely) marked "Fahys Bristol 25 years 8539235". And, now I have the movement out of the case -- the case is marked with: //\ // /// V (which I interpret as 3235) The bezel has similar marks: //\ // /// \/ (again, looks like 3235) Now maybe there is something about the "//\" marking that I don't know about that makes it a "9", but at least the case and bezel marks match. | ||||
| IHC Member 1555 |
looks like all the case parts are correct, sometimes people have used a bezel or back from another case and even though they look similar the threads are not matched thus making it tight to fit. I remember reading a post not that long ago where members discussed the best way to fix this issue, if you do a search you will probably find that forum discussion. Regards, Bila | |||
I see in another thread that some people recommend using a bit of water soluble valve grinding compound from an auto parts store. With the movement out of the case, put a bit of this on the threads and then spend 20 minutes working the bezel back and forth on the case. I am going to see if I can pick some of this up and give it a try. | ||||
