What would be a good UV light Ultraviolet lamp to harden the glue in replacing PW crystals. Would there be min or max wattages for the lamps? thanx ... jim | |||
IHC Member 376 Watchmaker ![]() |
Cas keer supply house in ohio sells these made just for watches i have one and they work fine with the right glue. If i remember right around 20.00. | |||
Site Administrator IHC Life Member ![]() |
IHC Life Member![]() |
I also have one as Phil shows. It works fine as long as you use the UV glue. Using the wrong glue has little or no effect on the crystals. | |||
