hamilton 916Go ![]() | New Topic ![]() | Find-Or-Search ![]() | Notify ![]() | Tools ![]() | Reply to Post ![]() | |
I'm stuck.When I wind-up the movement nothing happens,as far as starting to run goes.When I loosen one of the barrel plate screws(one closest to the train bridge) the watch starts running.Am I looking for a bent pivot? I am learning as I go.More than likley, I am missing something you more knowledgeable people know of the problems of these movements. I would appreciate some advice on how to proceed with this movement. Thank you for any advice. Frank Frank Juchniewicz | |||
First, I would like to thank Doug for his help.The problem was as he stated,namely thaat the Main spring cover was not seated all the way down where the "T" of the main spring protrudes up. I have seated it properly and now the movement runs great. The movement was purchased "as-is"at a local clock parts shop. The movement was bought to practice on. I dis-assembled it,cleaned,oiled,and checked for any broken pivots,jewels,or wheel teeth.Re-assembled it and thats where the problem showed-up.Thanks again Doug. Frank "Many heads are better then one" Frank Juchniewicz | ||||
| <Doug Sinclair> |
Frank, Glad to help. Thanks for the reply. Doug | ||
