January 12, 2014, 23:08
Roger StephensWinding and Running
Most of the watches I have start running as I am winding them which I believe to be normal.I just received one that doesn't.It requires a shaking to get it going and it will run 40hrs. and lose 3 seconds during this time.What causes this?Repairs needed?
Roger
January 13, 2014, 09:16
Joe BradleyIt could be that you have a different escapement such as a duplex, I may be wrong but I believe these normally need a shake. If it is a more common escapement that's ticking regularly and keeping time consistently as you've said then I don't think it needs a repair, but a clean may be a good idea incase dirt or dust s providing friction, stopping the watch starting without a shake and also increasing wear to the pivots. Hope this helps,
Joe
January 13, 2014, 09:47
Brian C.The movement maybe out of beat. If you haven't had it serviced, now would be a good time to do it.
January 13, 2014, 18:51
Roger StephensThanks guys.I was hoping that a service would be all that is needed.Appreciate your input.
Roger
